For your viewing pleasure
conkitchen
Curious to know what sticks out to you, besides the speedo needle & its noise as discussed in that other thread.
Perhaps the stone cold fast idle is wee bit high but it does come down when warm. So I know the choke is set up and working.
Edited by conkitchen
But what do I know
  • conkitchen changed the title to For your viewing pleasure
The Bristol engine bay sticks out to me.
And the fuel filter upstream of the fuel pump.
Not to mention the missing rollers on the hood hold-down bar.
And the turn signal stalk is on the wrong side :P
The antenna is on the wrong pillar.
I do like the paintless trunk roundel.
The gas gauge grounds are bad
Driver is suspect as well.
:P
  • Haha 2
  • Confused 1
Ray
1 minute ago, 2002iii said:
Why is the engine idling at 2000rpm?
The door buzzer is actually hooked up and working.
Sounds like the driveshaft shaft center bearing and/or guibo is bad.
Naw, see the above.  The fast idle at stone cold start up is as I stated a wee bit high.  It idles just fine off choke.
But what do I know
:P
Oh Ray!
It's Polaris not Bristol. Fuel filters? I smoke Pal Mal's up stream of my lungs so it's just fine for a carburetor.
As for rollers, well that's just how I roll
  • Haha 1
But what do I know
  • conkitchen changed the title to or your viewing pleasure
2 hours ago, bergie33 said:
Says who?  The dealer installed these wherever they wanted.  Mine is on the passenger side A pillar.
Hard to adjust from the driver seat. Wrong pillar.
Unless you're in the UK  🤪
Edited by ray_
Nothing!
Ray
Difficult to tell from the video if the rear window defrost is working.
Don
  • Haha 1
Don
