WTB: driveshaft for Getrag 235/5
JohnP_02
The reality is, the chances of someone having a 235/245 C/R driveshaft just laying around is around nil.
Just take a regular four speed shaft and have it shortened and joints replaced. Sourcing an original one if you can find one, will probably have lived a hard life (235s weren't babied). It will need to be serviced, and the time/cost won't make financial sense compared to getting one "made".
Most places won't even touch a BMW driveshaft anymore. Just get your measurements and order one online. There are several places with good referrals here. Try searching, I'm sure you will find a couple places to call.
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
4 hours ago, tech71 said:
A possibility at WN
WWW.WALLOTHNESCH.COM
Prop shaft 5- speed gearbox incl. center bearing and coupling, a= 560 mm, b= 956 mm, you need 1 for 1 car
Interesting.  Never thought to check WN.  Those measurements seem to match what I would expect for a 245 5-speed conversion.  Looks like you would need a 4 bolt flange for the tranny though, and you get the 8 bolt giubo.
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
Maybe not...  Pretty sure 235/5 transmissions  have a four bolt flange as well as early 245/5s
@JohnP_02 is your trans 4 or 3 bolt flange?
IE offers a shortening/rebuild service for around $600 + shipping.
At least with them you can be relatively certain that its not the first one their "guy" has done.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
This topic is now closed to further replies.
