WTB: Weber 32/36 and manifold
larryscastle
Hey Kendall,
Looks like the intake has port matching to the carb, all the vacuum lines closed off, and mild polish. I did a quick wire wheel to it but it still could use more cleaning.
Carb looks clean, butterflies are smooth, very little shaft play. I bought it used, so do not know the running condition or what jets are installed. I’d always plan a used carb should be rebuilt as needed, but I’ve bolted used carbs on in the past and they ran great with little adjustment.
I have several Weber air cleaner adapters too, just not pictured.
Rich
1 hour ago, larryscastle said:
To add to the list of questions… is there not a vacuum hook up for the brake booster? Couldn’t tell from pics, but any cast markings to indicate manufacture info?
Brake booster vacuum is still present - horizontal port facing the firewall.
No cast markings.
Not really fitting your WTB ad, my apologies. Just throwing out options!
