Tiger 500 CDI Box
JohnS
An ebay relic that I rescued.  I've always seen Mike Self mention these.  Kinda cool, but where did most folks mount the fairly large box?
Do I need it on my stock car?  Probably not.  Would it make a difference since I already run a Pertronix?  Probably not.  Still makes for a cool vintage piece.  A Flux Capacitor!
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
John, your PerTronix is an actually the BEST way to trigger a CDI. ( vs points).
Duals or a big cam would definitely merit running it, stock not so much. But it wouldn’t hurt anything and might benefit a bit. It’ll help most below 3000 rpm.
The on/off switch would let you try it out and directly compare with to without… :)
It likely hooks up like an MSD with the PerTronix. If you’re interested I’ll pass along that wiring diagram, if you don’t have one included.
I wonder if it needs a Tach Adapter like the MSD does? - Mike would likely know…
cool salvaging
Where we goin’? … I’ll drive…
I have a NOS one up in my attic parts stash...(also from Ebay) it was made by the same parent company that made the Delta Mk 10 CD boxes, just uses a different housing but AFAIK uses the same circuitry as the Delta units--with an on/off switch so if the CD box fails, you can revert to conventional ignition by pressing the switch.
Never tried one  with a Pertronix, but having installed a Delta Mk 10 on my '69 when it had 1300 miles on the odometer, I'm now on my second set of points after 226k additional miles... with a CD system, the points serve only as a relay, transmitting 12 volts instead of 30-40,000.
I always mounted my Delta boxes on the right side inner fender well, just in front of the windshield washer bottle (on 68-74 cars).  Manifold heat never seemed to affect it, as it's in the airflow from the radiator.  Admittedly the Delta box is somewhat smaller, but the Tiger unit would still fit.
  • Like 3
Same location here for my MSD, though closer to the strut. Good airflow and far enough from the exhaust - and close to the dizzy.
Custom length spacers help to getting a rectangular base mounted square at all four corners - the inner fender is actually a bit curvy...
I had wondered about that.  Good to know that the older Delta boxes are smaller.  I really don't feel like drilling any holes in my car, but good to know how most folks mount them.
Did you run yours with a ballast resistor and the matching coil or bypass it?
Thank you,
John
Edited by JohnS
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
 My '69 still has its original black coil and external resistor, so I run the Delta so equipped.  My '73 has a blue coil, but IIRC I took the ballast resistor out of the circuit, just left it there for appearance.  Both Delta units seem to work properly in both cases.
