WTB - 8 Bolt Crankshaft
cmsanford88
Looking for a stock 8 Bolt Crankshaft to replace one for a 76 2002. Machinist called and said mine has a hairline crack at one of the flywheel bolt holes, guessing it was over torqued at some point.
Will have it reground, also replacing timing gear etc. Would prefer one that hasn't been reground before.
Shipping will be to Atlanta.
Thanks!
Chris
Unless there was an oiling failure of some kind, don't automatically assume a used crank needs to be reground. It will cost more to buy a damaged crank and grind and heat treat it than to just find a good one. I've found it's easier to buy a block with a blown head gasket for cheap just for the crank. Kind of like buying an engine from a car wrecked in a front end collision, since at least you know the engine was running well...
This topic is now closed to further replies.
