Do I need the relay connected to the ballast resistor?
Go to solution Solved by tech71,
Do I need the relay connected to the ballast resistor(that I've removed) if I am using blue coil and 123 Bluetooth dizzy? Everything else is pretty much stock on my 73'
I've also removed all the smog stuff if that's important ( lemme know if you want it)
Thanks
