Trans mount bushing height.
Hans
IIRC they're within a few mm of each other if not the same.  And a couple of mm won't make that much difference.
You can also use the larger-than-stock mount from a Bavaria...
I can't locate the measurement of the E21 trans mount but do have "before & after" pictures that may help. New mount looks to be a tad taller when installed.
The original mount was rather squishy and compressed so couldn't compare actual dimensions to the new E21.
New E21 Trans Mount
I have a freshie from Blunt.  Measures 33mm.  Way better than the stock '02 mount for sure.  The gelatin coating might be adding a mm
Edited by JohnS
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
Important to me would be the height after both are loaded with the same weight.  Comparing "out of the box" dimension means ????
I suspect you'll find that height after loading is a function of time...
heh
Subjectively, the E21 mount hardly deforms, whereas the 2002 mount compresses several mm- initially.
also squishes when loaded.
