Original style engine hose clamps
CGoldone
If you actually have the clamps, but they simply don’t look good, the clamps generally respond well to re-plating in silver (a.k.a., clear) zinc. Separate the clamp from the tension screw for the re-plating process.
Thanks for taking the time to let me know this.  Did you see the images that I posted along with my request?   If your parts exactly match those ones, I’m very interested.  There are two other styles that look close but are later model BMW’s.
Could you take a close look and is it possible to take some images at different angles and send to me?  Also the vacuum and coolant clamps are different (don’t know why…!).
Do you know what year and model BMW they came from?  My car is a 1972 2002 tii.
Edited by CGoldone
Thank you - attached are some additional clearer images of the style of clamp I’m searching for, and the locations (for size) needed.  I don’t know the actual mm sizes but the smaller ones are 11-14 mm??
Also, the page from the BMW manual illustrating the clamps has spec’d by BMW.  A bit hard to see…
