Weber 38/38 Questions
2002#3
Go to solution Solved by 2002iii,
I have noticed Weber 38/38's (and probably other Webers, too) are often advertised as "for Ford V6" or "for Peugeot" or "for Ford Pinto" etc.
  • Are these carbs really mfg'd for specific makes?
  • Are any, all, or some of them adaptable to play well with an M10?
  • Are the differences in the linkages, tolerances, castings, etc. used in each make?
Thanks.
Edited by 2002#3
The 38/38 WAS specified for a particular V6-  mighta been the Cologne 2.8,
but I might be making that up.
In the early Weber books, it's shown with one bore feeding the right bank,
and the other feeding la rive gauche.
Thus, when you stick it onto a 2l with both bores feeding the plenum, it's
a LOT of carb, and not exactly calibrated to get off idle correctly.
Some can make it work better than others, and I'm sure there are manufacturing tolerances
involved, too.
la triviata
This one is "for BMW 2002tii"!!  :D
  • Compatible :Compatible with BMW 2002 1968-1976 E10, for BMW 2002tii 1971-1974 E10, for BMW 320i 1977-1983 E2; Compatible with Mercedes-Benz 280 1973-1976 114.060, for Mercedes-Benz 280C 1973-1976 114.073; Compatible with Jeep J10 1978-1986, for Jeep Scrambler 1981-1985, for Jeep Wagoneer 1980-1983, for Jeep Wrangler 1987-1989. Engine 4.2L l6 GAS OHV.
https://www.amazon.com/gp/product/B09QQ5SM51/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
