Crankshaft Sprocket
2002#3
Go to solution Solved by tech71,
Thanks, Toby.
Am I looking for a sprocket which supports two chains, one for the single-row and one for the oil pump (Photo 1)?
I have been (erroneously) looking for a sprocket that supports a single lonely chain (Photo 2) (that's all I see in parts diagrams).  I guess it's important to turn the OP, too.  It's this damn CovID.
It would be the one used on the 1.8l e21's. Unless you need a new sprocket you can run the double chain one and leave one row unused.
Edited by Son of Marty
Oh, yeah- if you found a truly one- sprocket sprocket, you'd have to run an external oil pump.
Which is overkill for 99.97% of the cars out there.
