Relay’s
bobbo
2 hours ago, larry_in_socal said:
I'm trying to understand what the rubber grommet is used for?  I assume it gets rolled down to protect from the metal lugs from hitting the body of the car?
That is exact reason because there is no evidence of relay socket. Wires are direct  connect to rely tabs.
76 2002 Sienabraun
2015 BMW F10
That unidentified relay is not going to do anything without a 4th wire.
The Red wire should be connected to the #30 tab on the relay.
The "load" ie fuel pump, driving/fog lights etc. is connected to the #87 tab.
The Brown ground wire is normally connected to the #85 tab.
That leaves one tab (#86) that is the 12v trigger source.
Looks like your relay is a Bosch 12V 30A 332 019 151.  I use 4 of these in my car.
John
