recommended oil
Hano
Go to solution Solved by Mike Self,
Fred:
It depends on your location, climate and intended use (street, track, towing, etc.).  The 1600 like to Rev a little higher, so that might make a difference.  My original owners manual for my 1600 calls for 30W for temps above 32F and 10-30W for temperatures below 32F.
Search is your friend!
Mark92131
1970 BMW 1600 (Nevada)
For years and years,  I used Kendall GT-1 30w.  Always very pleased with it, but no longer available.  Have been using Valvoline VR-1 20w-50 and straight 30w when I can find it.
1970 Granada 1600 "The 16",  2000 528i Siena Red "The 5",  1968 Mustang 289 Muscle Car Blue,
1999 318ti M Package Green,  1982 633CSi 5 speed Blue,  2011 550i M Package Black (6 speed manual)
Be sure what ever oil you use has a high zinc content to protect your cam shaft, not many of the oils that are formulated for new cars will have enough zinc for a m10 to use.
George S Patton
Castrol now offers the GTX 20w-50 in a “classic” formulation with ZDDP.
  • Like 4
  • Solution
Since I don't drive my cars when it's really cold (below 20 degrees F) I've been using 20w-50 for many years--conventional oil before the 73's overhaul, and 20W-50 Redline since.  Seems to work just fine--but I did notice that the synthetic oil shows a few lbs less oil pressure than conventional oil.  Just enough to notice, not to worry about.
PS  still use conventional 20w-50 in the '69 as it's never been rebuilt and I don't want to change either brands or types at this stage in its life.
Either works, they are built for flat tappet cam/follower designs.  Super high oil pressure is not an indication that oil is flowing through bearings, it's all backed up in the galleys.
What's the recommendation for a cylinder hone and new rings?
Rod and crank bearings are in good condition.
Head was rebuilt 5k miles ago and working well with Valvoline VR-1 20w-50.
Thanks,
John
John, if your using a machinist use the oil they recommend, otherwise use a break in specific  oil. But before you settle on a ring job be sure to have your pistons checked out especially the ring lands this is a known m10 weak point.
Edited by Son of Marty
George S Patton
Original pistons are within factory spec.  They look new!  I was actually hoping they would need replacing ... with higher CR.
The original rings were very worn and clogged with carbon, but the cylinder walls were perfect and only needed a light hone to deglaze.
  • Like 3
Survivors high milage engine needs a quart+ top up every few weeks so this stuff is great for that.
At $3.29 a quart, its the cheapest I have located near me.
Made by Valvoline.
Once the overhauled engine goes in I may go with the high zinc Castrol 20-50 but honestly... Been driving 02s for many years using regular oil and camshafts have not been an issue, ever.
I think frequent, regular oil changes with proper SAE rated oil are way more important than what brand you use.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
