M10 Engine CAD Model
I was playing around with a new 3D scanner and an old engine block I had sitting here. The block was dirty and there are a couple spots with some "phantom surfaces" (in the opening for the starter, for example). It still needs some cleaning up to make the bores and surfaces correct. But... All the bolt holes should be in the right place if any of yall want a scan to build some attachments/brackets in CAD.
Scanned it with an Einstar 3D scanner, for anyone that was wondering.
Enjoy!
M10BlockComplete.mtl M10BlockComplete.obj M10BlockComplete.stl M10BlockComplete_Project1.asc M10BlockComplete.SLDPRT
  • Like 9
  • Thanks 3
Hey, thanks!  I was just farting around in MeshLab last night...
one piece at a time, eh?
What has your experience been with bringing the scan data into Solidworks? I am using the same scanner and after a week or two of trial and error, sulked back to Fusion 360 with my tail between my legs. Any alternatives to AutoDesk products are welcome, with a priority on locally stored data rather than cloud.
-Tom
1974 green 2002 tii
1995 525i -ish
On 1/15/2024 at 9:54 AM, Santawillis said:
This looks great! would you be able to scan the head as well as the valve cover to make 3d models? I believe the one on Thingyverse was taken down and this is already an STL file so it would work great!
Rafael
I only had the block laying around.
once you finish exporting the .stl file from the scanner software, it is pretty easy to work with... only finicky thing was that SW prefers that the scan be a closed body. You do that in the scanner software by processing the scan as a "watertight" model.
When you open the STL in SW you have to go into the options and select "import as solid body"
From there its business as usual.
Ah, that would do it. I have been working on projects with it where there is no way for me to make it watertight. The other engineers at the office agreed that solidworks struggles with open mesh and surface data like this. But good to know that it will work for more complete scans!
-Tom
1974 green 2002 tii
1995 525i -ish
Ooooh! I'm going to be watching this. This is awesome! I've got a couple brackets I want to look at making (LS coil holder, etc) for doing megasquirt stuff. Thank you for sharing! If you're around Seattle I'll happily loan you a head to scan. Wish I had a whole engine assembled....
-Nathan
I've got one on a stand, but no scanner.  And probably not the patience to operate one...
but dang, a tight mesh of an entire head, inside and out, would be a LOT of fun, wouldn't it?
can I do it with a $30 lidar module off ePay?
2 hours ago, Dudeland said:
I would love to get a scan of the engine bay and/or the subframe.
That would be hard to fit thru the door into my office, haha! so scan something that large it would be best to have a wireless scanner that stores its own scans and then uploads them to your computer, but then your talking $20k-$40k. Mine has to be connected to a computer since it is just the scanning tool; the PC is doing all the heavy lifting during the scan. Smaller things like the block and the head are pretty easy/quick because I can drag them in the house and plug the scanner into my racing-sim computer. It has enough memory and graphics power to take whatever I throw at it. For things I cant get in here, i can run the scanner on my Surface, but it struggles and the scans are sloooooooooowwwwwww!
I wonder if there are people that could scan one for me.
"Goosed" 1975 BMW 2002
