Weber 34ICH Conversion
My NK has a weber ICH on it, I installed it to replace the factory solex. It works nicely with a stock motor, and I doubt it's useful for any modified engines! The electric idle shut off solenoids can be a little finicky, as well. I had to replace a sticky one that was causing a stalling issue. What year is your NK? Mine bolted right in, with no need for linkage modification.
I'm getting a 2000/69 but I don't have it yet. I assumed it is a manual choke. I'm also considering a 32/36 conversion.
1962 BMW 700 Cabriolet "The Mighty Cabriolet"
32/36 will require a different intake manifold, as I’m sure you’re aware. But it will also require a custom linkage system, as standard 02 throttle linkage options for the 32/36 won’t work on an NK. I don’t imagine a custom linkage would be overly complicated, however I haven’t given it a shot myself. I will cross that bridge when I finish restoring my Alpina side draft carbs😊
the 34 ICH is a bolt in affair and fits right under the factory airbox, which is nice. Here is my 68 2000, for reference.
Noce Kofferaum!
3 hours ago, mcmil said:
Noce Kofferaum!
thanks! Is this your first NK? They are AWESOME!
No. My fifth.
65 Granada 1800
65 Bristol 1800ti/sa (995089)
67 Polaris 2000ti (painted white by PO)
67 Polaris 2000tilux (mit tii motor)
Current project: 69 Granada 2000/69 US Spec
Sadly I have none. Just a poor college student at the time. 😔
On the bright side,  I'll be co-pilotng my friend"s TISA to The Vintage next week in NC!🙃
Posted (edited)
I'm reluctant to name the owner without his consent. I can say it's 995107 and he has posted here.
Edited by mcmil
More text.
