Third brake light wiring question
Go to solution Solved by John76,
1972 2002tii
I'm installing a third brake light.
I see the wiring bundle on drivers side in trunk. I thinking I’d tap into the green/red wire for power and brown/yellow for ground. I didn’t get clarity from the wiring diagram I have.
Does this seem right?
2003 e39 M5 (daily)
1986 e30 325es (sons car)
Br/y does not sound right. Plain brown is usually ground. I have made separate ground to chassis for 3rd brake light.
Posted (edited)
The green/red goes to brake switch on a ‘73 onward model diagram.
Not seeing the brown/yellow in the trunk bundle on this diagram but the elec diagrams aren’t always totally correct 🤔
Karl’s suggestion above puts it beyond doubt though if you have an assistant or even a stick to depress the brake pedal so you can check. A house painters extendable pole works great.
Edited by zambo
That brown/yellow is your fuel level sender, don’t tap into that.  Green/red is your brake light, though. Everything in the trunk grounds to frame in the corner, so I’m pretty sure you don’t even have a ground in that bundle to the trunk. I just ran my third brake light ground to frame…I sank a sheet metal screw on the C pillar.
Posted (edited)
Just look at the wire connected to the brake light bulb!
Edited by jimk
  • Haha 1
  • Confused 1
The colors mean something 🤯.
George S Patton
I just teed off the terminal on the taillight housing rather than hacking the harness (in this case).
  • Like 3
Ray
+1 Ray!
Find the brake light bulb in your roundie and connect to the + and ground (you can ground your 3rd. light anywhere).
Here's how I did it on the passenger side square-light.
The multi color brown threw me for a loop. I knew it wasn't right for a ground. I was trying to keep the new wire length short and not have to go all the way back to the taillight. Taillights ground in the middle behind the brace so I can't see them easily, or access them as they're bundled up in tape.
My wiring diagram doesnt show my side marker lights either, which I see are grounded to two brown wires. Again, I was hoping to keep the wiring to a minimum. And I didn't want to drill a new hole to do a new ground.
Looks like I'm extending the wiring to the taillights and grounding to new chassis ground...
2003 e39 M5 (daily)
  • Solution
Pablo,
You only need to attach the + wire from the new 3rd light to only 1 taillight.
Here's the connection for the side marker light and ground wire.
11 hours ago, JQ02 said:
@Pablo M do you mind sharing a pic of the finished brakelight?
I'm curious what light you went with and where you got it?
Thanks
Sure thing. It was one of the lights someone here used. I picked it up from a previous thread.
It’s this one (no longer available, but for information only): https://www.amazon.com/gp/aw/d/B076F4Y98W?psc=1&ref=ppx_pop_mob_b_asin_title
It matches the slope of the glass very well. I also have a thin LED strip I was thinking of using. It would have been more stealth but needed to figure out mounting. This one self adheres to glass. Does the job, doesn’t look too bad.
2003 e39 M5 (daily)
