Tractor sounding '02 - Help!
Go to solution Solved by Dudeland,
Posted (edited)
16 minutes ago, NicholasMav said:
It's measuring 128.93
Oh you’re good, standard 1.5 mm head gasket would be fine. Guess you could have held on to the one you returned😉
As far as brand.. well, people’s opinions vary, I’m partial to Fel Pro but have used Victor Reinz and Elring head gaskets on occasion as well with no ill effects. A Cometic gasket is probably not warranted and yes, they be expensive.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
  • 1 month later...
If anyone is still following this, how clean does the block surface need to be? I’m concerned about the circled area, and other areas similar.  Carb cleaner/brakekleen isn’t removing it.  I would think a razor blade would be a bad idea.  IMG_4084.thumb.jpeg.c660bd742946c59f8265af28b18de4ee.jpeg
I'd aim to clean all that up as much as possible. Maybe start with brake-clean and a tiny square of scotch-brite? That's the least-abrasive path you could take to start with. Perhaps a bridge too far, but when I did my motor I spray-mounted some wet-dry to a piece of plate-glass I had lying around, and used that to flatten everything. Just avoid over-doing it between the cylinders.
Edited by 2002Scoob
Yes, needs to be much cleaner. Carefully remove the head-locating dowels, place some rags/paper towels in the cylinders to catch debris, then use brake clean and sandpaper on a firm FLAT board to polish the deck. Remove heavy old gasket material with a razor blade. After clean, vacuum out the head bolt holes and try to hand fit the headbolts... you should be able to run them all the way down by hand. Any that feel rough or won't go, chase them with a tap and repeat the cleaning/fitting.
side tip, fill your cylinders with tightly packed paper towels when doing this, and use a sparing amount of oil as a lubricant when 'wet' sanding. because water and iron... and also abrasive-loaded liquid anything is not something you want to drip into your rings.
Beat me to it :) I didn't remove my locating dowels, but I started with a fair bit cleaner deck than OP, and just sanded around.
Note, that's evaporust filling the water jackets. Pay no attention, just being OCD. haha
IMG_1967.thumb.jpg.4448250e18c0937201d8a4d5782dc2b6.jpgimage.thumb.jpeg.4db2b5e16acf520aff02c3452b84f40d.jpeg
Edited by 2002Scoob
I use a fine scotch bright rotary pad dry, just be sure to keep moving and don't stay in one spot, I coat the cylinders with a coating of grease on the cylinder walls then stuff a paper towel (ala Scoob) in them.
PS. If you choose to do it wet mineral spirits add a bit of lube and it doesn't evaporate right away like brake clean.
Edited by Son of Marty
George S Patton
