Sterring Wheel Horn Connection
Go to solution Solved by JohnP_02,
Hi all,
I have a 1972 TII. It came with a new Nardi wheel and hub. I pulled the wheel off and found no wires. How do I get this connected??
There are no wires to connect. Is the problem that your horn is not working? In order for the horn to function properly the Nardi hub should have a contact pin that touches the brass slip ring at the top of the steering column.
1969 2002 Granada, 2nd owner
1976 2002 Fjordblau (sold)
A few too many steering wheels
  • Solution
You need a new horn contact pin set up. Remove the old empty rubber housing at the bottom of the hub and install a new set up then connect the spade end to your horn button. These are readily available
Your welcome. I do not have any steering wheels for sale. Just have the ones I am keeping in my collection. You try posting in the wanted to buy section. Good luck!
