Seven years in the making
Thanks, I agree.  I removed the front and rear side reflectors almost immediately and welded the holes closed. I think that was a US requirement, but I never liked the look. Much cleaner without.
To patch the marker light holes take a 1 inch hole saw and drill a scrap bit of sheet metal and the cut out bit is a prefect fit for the holes.
George S Patton
2 hours ago, lunarkingdom said:
What size rims with what offset are you using? They look like the fit perfect and would tuck with a little camber adjustment or even as is (would be close). They look great!!!
Those are 16x7 et25. I have 195x45 tires on. I can drop the suspension front and rear to tuck the tires under the fender. The back can drop as far as I want, the front will rub in turns if I go too far. As it is, I have the tire about even with the fender and it’s plenty low. Much lower and I have a hard time getting into the garage. 😂
Front camber is ~2.5, rear is a little less than 2.
Because of my steep driveway, I had to weld up these to navigate the break-over at the threshold. It’s a squeaker.
