front strut cap needed
walkinfool
FYI, be very careful when installing either black or grey caps on new upper strut mounts.  The lip that retain the cap is significantly wider than it was on the original mounts, and will split your cap if you try to force it on.
I found that out the hard way, even after trimming the lip.  I did come up with a McGyver fix, though, PM me if you'd like a copy of the column.
  • Sad 1
This topic is now closed to further replies.
