Help with fuse box wiring layout
Go to solution Solved by visionaut,
The other day I started swapping in my new Holy Grail fuse box. By the time I had swapped over the first row of wires I realized I had bought the wrong fuse box (for post 1973 cars).
I went to replace the wiring, one spade at a time, but it looked different installed and I don’t recall a gap, an empty spade being there before. Now I’m freaked out I installed them wrong across the 12 spades somewhere. Afraid to start the car for fear a fire. Electrical work freaks me out.
I checked wiring diagram and not helping. I didn’t take “before” photos. Lesson learned.
Can anyone look at this and confirm if I’ve got this top row correct? Also photo of the wiring diagram layout.
The green wire I added to an empty spade to power my driving lights (yes, it has inline fuse too). I don’t recall another empty spade and wiring diagram shows the wires totally different. I’m certain I didn’t get it that wrong!
1972 2002tii
6 should be on left in photo above.
Edited by Pablo M
2003 e39 M5 (daily)
1986 e30 325es (sons car)
Had a look into my fuse box box today:
Left: 71-73 roundie.                                                         Right: 73-77 squarie.
Both euro parts. The 71-73 can easily be identified since it's got both crosswise and longwise spades what the 73-77 part does not have. From above you can see how the inputs are grouped:
I added some duck tape to underline. In the right row of the right box inputs #3 and #4 are also paired. So telling from Pablo's pic I'd say it's the correct box for a roundie and since there seem to be plastic intake runners he's got one.
Euro 71-72 roundie diagram:
Note that this is belongs to cars with the rotating fan/defrost switch. 72-73 roundies already have the slider for the fan above the heater control- at least on this side of the pond.
henn
  • Like 3
On 7/22/2024 at 6:42 PM, visionaut said:
Not sure if these might help;
71 box:
73 box:
Thanks! This is exactly what I needed. Looks like I did install a few wires one or two spades off.  Assuming this 1971 diagram is same for my 1972 tii box I should be good to go. Thank you!
2003 e39 M5 (daily)
