36 minutes ago, popovm said:
Anything us US folks can do for the Canadians, i.e. ship some of the 3m stuff as a “gift” or will the mounties getya?
Ha, I appreciate the offer. I'm going to try the Mastik first, since I already have a can of it.
1975 - 2002 - Sabine - Jade
2010 Toyota Matrix XR
Remember: RACECAR spelled backwards is RACECAR
Nice. The adhesive smuggling offer is still on the table if that doesn’t work out. “Operation Black Maple Syrup”,  if you will. 😄
  • Haha 3
Just have 3m deliver what you need to Moosealvania (it's just outside of frostbite falls MN) then wait for these guys to row the island to Canada.
x720
Edited by Son of Marty
  • Haha 3
George S Patton
Ha, that made me LOL. 😃
I tossed my BMW trunk seal in the washer with a load to strip the mold release, air dried.  3M Super Weatherstrip glue and clothes pins to keep it clamped while drying.  Good to have an extra set of hands while you are gluing and clamping.
Mark92131
  • Like 4
1970 BMW 1600 (Nevada)
Mark way to think outa the box, hope it works out it would save a lot of very boring work.
George S Patton
Mark92131
Nice, now I know how many clothes pins I need. I was going to hit the Dollar Store to grab some. I was also thinking of taping the corners down for 24 hours or so, since they're the points that need to bond the strongest. And yes, I will employ a second set of hands.
Posted (edited)
Success? Time will tell.
Off topic, but it’s nice to be a member of RCLUB where I can work on my car 24 hours a day. You can book one of the two lifts or the wash bay any time. Comes in very handy.
Edited by Senna27
  • Like 5
Ah Toronto.... so far away. Nice digs, I bet that's a lot of fun.
I like the clips, where did u buy it? Canadian Tire? Dollarama? Princess Auto? HD?  I’m also from Toronto and ready replace my rear seal too. What’s the rationale having the pink on the corners? Are those clips supposed to be stronger being the corners need that extra attention?
I bought the clamps at Dollarama. They’re all the same. When I was picking them out, my wife said, what, you’re not gonna get some pink ones? lol
The clamps work well but they’re cheap. Only open them far enough to get it over the seal. If you open them all the way, they’ll break.
Just be sure to prep the surface of the seal by sanding it, then wiping down both surfaces with alcohol. The Mastik One seems to be good.
Apply adhesive to both surfaces, let it dry for 24 hours then apply one more thin coat to the body, let dry 3 to 4 minutes then install the seal.
I started by lining up the seam in the seal with the trunk lock, worked my way to the right rear corner, then quickly clamped that corner. Next, I worked my way from the trunk lock to the left rear corner, then clamped that corner in place. Since those are the two sharpest radius corners, I wanted to have the least amount of tension on them. Next, I continued towards the front of the car around the left corner, then continued on the right side and around the right corner, clamping both those, then finished off the straight section at the front of the trunk. It says it’s fully bonded in 24 hours so I left it to sit overnight with the clamps on. I’m going to take them off this morning.
This was a great description but “Apply adhesive to both surfaces, let it dry for 24 hours” - is 24hour to long before moving to the next step (adding a thin coat)?  I never did this before so I don’t want to mess it up.
It'a a tough job to get a good seal because the oil drains from the block and across the bottom flange forever (unless the engine hasn't been run forever).
  • Confused 1
No, you want it to dry completely on both surfaces, for 24 hours before you install the seal. After 24 hours, you apply a thin bead to the body side and wait 3 to 4 minutes before you start sticking it down. These are the Mastik One instructions. Two days later, I’d say it worked perfectly.
Huh? Wrong thread maybe…
