Selling my beloved RaceCar - 69' 1602 For Sale !! VARA/SVRA
Price: $30000
Description:
The "famous" BMW1602.com car is FOR SALE !!
WhatsAppImage2024-09-16at16_08_32.thumb.
The website no longer exists but many that have been around for awhile will remember it and the length build threads I have maintained on here and bimmerfoums.
Every part of this car has been documented and public first via the website I had for it and then thru the 2 build threads. Many of the images are gone (photobucket error) but ultimate I also re-posted most of the images and updates of the car on the INSTAGRAM account for the car located at
WWW.INSTAGRAM.COM
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.
Build Thread here!
All that said.... Last time the car raced, I got pole position and won one of my races. The car finally is running great, reliable, fast and handling great. It's pretty much ready to line up for the next race and be competitive right away. Finished second in the championship.
The amount of work and detail I have put into this car is hard to add up into a reasonable value. The cage is extensive and really improved the car. One of the cars most striking features.
Lots of really nice expensive details on the car such as the interior sheetmetal work (alum. panels, door caps, dash), expensive seat etc etc....
Here is a quick run down of the car.
1969 1600-2 Chassis
2.0L Race engine built by Kevin McDonald
Race weight: 2002lbs (really)
Races in VARA race series since 2007 in the BSL class (Logbook included)
Also Legal to race in SVRA BSL class
**That said if you would prefer to race in BS class the car is easily converted with just the addition of dual sidedrafts (DCOE's) which is really the only differentiator between the 2 classes**
CHASSIS Details:
Bare metal prep
All RUST cut out removed and repaired
Seam welded
Extensive cage that extended thru the firewall to the front framrails and in the rear connected into the rear subframe mounts/diff/shock towers
Door X's with gussets
Jack point that ties into the cage that makes for easy single jack point lift per side at the race track.
Solid rear subframe mounts
adjustable rear subframe (camber)
Custom welded reinforced "boxed" dimple died rear trailing arms
poly bushings on rear suspension and rear diff mount
poly front bushings
Custom welded reinforced "boxed" dimple died Front suspension arms
Reinforced front subframe
CNC roll center spacers on each strut (corrects arm angle on lowered cars)
Poly steering bushings
Reinforced front shock towers
SUSPENSION Details:
IE special race valved (shortened) Front and Rear bilstein struts
IE rear spring (race)
Eibach front spring (race)
Billet Camber plates
Adjustable Rear subframe kit
IE front and rear Adjustable (race) roll bars
Years and Years of setup and chassis tuning to get the car finally handling like a champ.
INTERIOR Details:
Schroth window net
Schroth 6pt. harness
OMP HTR Head containment carbon fiber seat
VDO Extreme smart tachometer Gauge
Autometer Oil press. Mechanical Gauge
Autometer Oil Temp. Mechanical Gauge
Autometer Water press. Mechanical Gauge
AEM Air Fuel Meter and (O2 sensor in exhaust) for carb tuning
Momo Mod.07 steering wheel with quick release
IE Fiberglass CSL Dash shortened and with custom aluminum formed end caps
Custom aluminum formed door caps
Custom aluminum formed door panels
Custom aluminum formed rear firewall (removable)
Custom aluminum formed Center Console (for all the switches)
Longacre panoramic rear view mirror with cnc roll bar brackets
Longacre Master electrical cutoff switch
BODY Work Details
IE Turbo wheel arch flares
IE Fiberglass Hood
IE Fiberglass rear deck lid
"Bullit" Style vintage race mirrors
Aluminium headlight covers
IE abs airdam
Fiberglass turbo airdam (not installed but included)
Bare metal painted in 2007
Deleted all trim holes
Deleted fuel door "shaved"
FUEL System Details
Fuel Safe 10 gallon fuel cell with foam
large fuel filter (race spec)
Holley Red fuel pump
Holly Fuel Pressure regulator
Full AN braided lines to the carb
Safety Details
ESS Fire suppression system with 4 nozzles (2 each side of engine bay, one on driver, one on fuel cell
HandHeld Fire extinguisher with cnc roll bar quick release mount
Electrical Details
Full rewire in 2019 by Ronin Autowerks
New switches, buttons by Ronin
MSD 6AL digital Ignition
MSD Blaster HVC2 Coil
New IE plug wires
Modified Pertronix ignitor rotor
Lightweight race battery with custom mount by Ronin
Drivetrain details
Getrag 5 spd transmission (recently rebuilt)
New clutch & pressure plate *race spec* (recent replacement)
New guibo
New driveshaft
Diff #1 - 3.91 LSD rebuilt with higher lockup and new plates
Diff #2 - 4.10 Welded and rebuilt
AKG Short shifter "DTM" style
New CV's axles
Tires/WHEELS
Freshly restored BBS "basket weave" 1 pc 13x6 wheels Fresh powdercoat.
205/50/13
Recently replaced studs and wheel nuts
BRAKES details
IE "volvo" big brake caliper upgrade 4-piston
New Slotted rotors
new brake lines
New larger 22mm rear wheel cyclinders
fresh bleed
Rebuilt pedal box by Ronin auto
Massive balls not included.
ENGINE Details
Race engine build by Kevin McDonald
Race winning, pole position capable Dyno numbers
Race prep'd block inside painted with Glyptal modified in a few places for improved oiling
Coated bearings with custom mods for improved oiling
Pauter I-beam Rods
Custom cam "304"
new oil pump
High compression pistons around 12.5 : 1
Racing OIl pan with trap doors, windage tray and extra capacity
Ported 121 head with new valve guides
IE stainless valves (bigger I think)
Light Intake port job
IE rocker clamps
Shot peened and magnafluxed rockers
Custom valvecover
Ronin custom Stainless Steel race header "alpina style"
Ported and matched downdraft intake manifold
Modified Weber 38/38 downdraft carburator "race spec"
new water pump
Intake/carb spacer
Remote oil filter
K&N racing oil filter
Setrab 19row "new" oil cooler
Large aluminum racing radiator
Electric fan - switch controlled by driver
AKG engine mounts
s14 starter
IE "racing" crank pully CNC
SPARES/Extras
Misc boxes of "stuff"
Headgasket
Extra DIFF
Full box of jets for the weber carb $$$
Passenger seat (carbon momo)
Passenger Harness NIB
Not Included but available for purchase separately
Set of 3pc Ronal Magnesium racing wheels (very lightweight)
Set of 3pc BBS Magnesium racing wheels
Hans Device
MOST OF ALL.....
I spent years "shaking down" the car....working out all the bugs and issues you just can't predict without racing the car. At this point the car is finally sorted of most small surprises and issues and also sorted from the larger issues.
The suspension and chassis setup is really the KEY element and the car is handling like a dream on rails....I was passing people on the outside of turn 2 at willow confidently....
I ran q 1:39 laptime and honestly with a bettery driver and fresh tires it can easily run 2 seconds faster.
Basically you would be buying a car that's ready to race and be competitive for the BSL championship right away.
The only thing that needs some loving....is the paintwork. Like most race cars it could use a makeover. I was about to maybe put a custom wrap on it instead of a new paint job.
Anyways, feel free to contact me I could answer all your questions. The car is in Burbank and is available for viewing by appointment.
It's painful to part with as it's basically a part of my family, like a son. But the time has come.
It's ready to give the new owner lots of thrills and good times.
m3pedro@hotmail.com
310.592.8450
Edited by bmw1602.com
68' 1602
98' ///M3 Sedan
88' ///M3 Sold *
06' ///M3 Competition Pkg Sold *
http://www.bmw1602.com/
