What year 3 series radiator will work in an 02?
the early ones were copper which is more efficient, but the later aluminum ones are still supergreat on an 02 and are a little lighter. HTH! :)
-Rob
with longer bolts. The thing is that the flanges with the holes in them on the side are on the opposite face of the e21 radiator. So you need to just make some tubular standoffs with a bit of some skinny pipe (PVC pipe would probably work) and use long bolts to mount it to the stock locations. on the e21s, the radiators actually mount with different moutning holes.. Its obvious once you see one... Hope this helps too!!
-Rob
