1970 turbo build-up - update 08/14/07 - running
jakeb
I have started the turbo buildup of my 1970.
Here are the specs/mods so far
new paint..2years ago
h&r/bilstein sports
poly bushings
kmac front strut mounts
320is recaro sport seats
320i 5 speed
320is 3.91 LSD
23/19 mm sways
front shock tower stress bar
battery relocated to the trunk
turbo engine
Specs on engine....
8.5:1 comp
292 cam
ported/polished head
rebuilt garrett t3 turbo, .60 compressor / .48 turbine, internal wastegate
equal(almost) length tubular exhaust manifold
intercooler
I will be running megasquirt eith edis ignition, wideband O2 sensor, etc
Today I disconnected everything currently connected to the old engine. All that is left is motor and trans mounts and out it comes.
A couple of pictures...taken with a camara phone, all i have right now and will update as the project progesses.
This is right after the manifold was built...it now is fully welded.
Update: (8/14/07)
It runs! It drives!
Pictures...
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
will your turbo hang high or low?
either way, you may want support brakets...ask me how i know ;)
Pat Allen
1985 XR4TI, 22psi ±300hp
Up high...like yours. I will make sure I work on a support of some sort...
more pics...
Make sure you "clock" the center section of the turbo to get the oil drain pointing down. Looks great. I would sugest after you get your manefold all set up, get it ceramic coated. It will make it last a lot longer and will help keep the under hood temps down.
You gonna blow through that 32/36? That would be truly old school. EFI would work better.
John
1665778
Yes I am using megasquirt. That is the old engine in there right now...about ready to come out and wanted to make sure everything is lining up after the manifold was welded completly....
I have thought about getting it coated..
jake
  • 1 month later...
Small update...
Engine is out, waiting on a couple last parts for the new engine.
Rebuild the re-end and CVs...all back together now
Been taking some time to fit in the intercooler, 27" x 6" x 3"
as well as the oil cooler.
Here are a few pictures.
  • 3 weeks later...
  • 4 weeks later...
Engine is running!! Will be switching to edis in the next couple days I assume and then start working on the fuel side of things.
Happy that the project is moving forward again
