Rear end woes...
72touring
I started my 1971 2002 last night. Everything sounded perfectly normal. I let the clutch out and felt a loud thud that appeared to come from the back. I push the clutch in and release again. This time all I get is high whine and no movement/power to rear wheels. As I let the car roll into another parking spot (with engine off, ignition on, car in neutral), I noticed a pronounced clicking sound. I haven't had a chance yet to crawl under it. Guibo failure I've experienced in the past sounded nothing like this. Thoughts? And as always, thanks in advance...
Paul Huber
2000 Touring tii in 1/18 scale
There are likely a number of possibilites.... one of them is a failure of the spline in the rear stub axle, that connects the half-shaft/CV Joint assembly to the rear wheel hub.
Not one of the first things you might think of... but the symptoms you describe appear to fit.
Good luck...
can loosen, then break one at a time 'till they're all gone. And without a limited slip, you're going nowhere! Happened to me twice--first time I caught the loose bolts, the second time I had to do a parking lot repair.
ditto.. happened to me about a year ago. pretty simple fix..just replace the bolts or retighten them. Hope that is it. Cheaper than all the other possibilities.
