What kind of Lug Nuts do these wheels need??
InkaSteve
I have 4 of these Ronal wheels that I am cleaning up.
It appears that the holes for the lug nuts are larger than on my other wheels and there is no tapered seat. So I am assuming that they require a different type of lugnut. If that is true...What kind do I get??
Thanks in advance for your advice..
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
for 'Mag' style wheels- they have a small sleeved- down neck that centers the wheel on the studs,
and a small washer that catches the shoulder and spreads the load onto the wheel.
Most speed shops carry them- make sure you get the
right size washer to fit into the recess on the wheel.
Metric 12x1.5...
Mag shank is the style lug nut. BBS still has them with the proper size head(19mm). You just need to determine the lenth of the shank and diameter of the bore. The washers are built into the lug nut.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
If you happen to need .746"L x .679" shank dia nuts + washers, I have a once used, McGard set of 16 in new condition. I bought the wrong size (for Minilites) and installed them before I realized my error.
They're just toy boat anchors at this point, so you can have them cheap ($20) if you'd like. They're p/n 61002 on this list:
http://www.mcgard.com/search/default.aspx?PrimNavID=1&NavID=11&GroupID=45
email me if interested.
MichaelP
BMW_CCA Blue Ridge Chapter
'71 1600
'71 2800CS
'73 3.0CS
'91 318ic
http://www.crismanpetrus.us
