HELP..Ign. Switch jammed. I am stuck at work.
InkaSteve
Did stupid thing. Accidentally used wrong key in ignition. Started!! but jammed turning it off. Was able to pull wrong key out but switched jammed just short of locking the steering column. How easy is it to remove the switch?? My Haynes is at home. Immediate advise would be appreciated. Removed everything surrounding the switch, but don't know what to do now. Time is of the essence.
Thanks in advance for quick response.
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
If your column is not locked and the switch is exposed you can hot wire it to get home. I don't know what color wires you need to cross. I used a test light to figure it out when I had to hotwire my 69.
good luck,
Brad
73 M2 evolving project
77 Datsun 620 king cab hauler
09 XR1200
77 XS650
78 SR500
half dozen ct70s
other wheeled madness
If you just need to start the car you can remove the actual electrical part of the switch. Look at the very back of the lock cylinder where all of the wires go in and you will see 2 small slotted screws. Remove those and the back portion of the switch will come off. You can can then use a screwdriver or similar object to turn the plastic switch. I am sure all of my terms are incorrect, but once you remove those two screws you will see what I am talking about. I had the same problem with my ignition switch jamming.
Thanks, Brad, and especially Dave, I owe you "big time".
Column was still unlocked, pulled switch off the back. Success....!! Now I can use the "evil" wrong key and turn the switch. I will worry about the lock itself when I get home. As of now, I can drive anywhere I want, just have to lock the car when I stop.
Thanks mucho to all. Again, the FAQ saves another. Couldn't do it without all of you.
Glad I could help. I also have an article on how to repair the lock cylinder. If you are interested email and I will send you a copy. I just went through the same problems with my 69 and the faq was a huge help. I am glad I could return the favor.
I was able to remove the tumblers from the lock on my '68 1600 and put it back together. Any flat tool would start it then. The best part - nobody knows this but you. I had a friend who's '56 VW key was broken off in the switch. He kept a screwdriver sitting between the seats and drove it like that for many years with no problems.
-Jerry
Jerry
no bimmer, for now
-Jerry
i pulled mine apart and re-keyed it to a blank- never need to have a key cut again. shhhhhh
