piston guide question
steve k.
8.5:1 CR U.S. "Spec" piston on 1968-1972 2002's
42.3 mm pin-to-deck, flat top
9.0:1 CR U.S. "Spec" piston used on '72 US-model 2002tii's
9.3:1 CR European 2002TI (twin-carb model)
42.1 pin-to-deck, 5.2mm dome
10:1 CR Early euro-spec 2002tii
42.5 mm pin-to-deck, 4.4 mm dome
E12 Head:
6.9:1 CR Factory "Turbo" pistons (used on 1974 2002 Turbo)
42.0 mm pin-to-deck, 3.7mm dish
8.1:1 CR flat-topped piston (much like the 8.5:1 CR used on the
121 heads) used on '75 US-model 2002's, also on most
US-model 3-liter cars of the era. (keep in mind that
the 2-liter 4-cylinder with the E12 head and 3-liter
6-cylinder cars can interchange pistons)
8.3:1 CR U.S. "Spec" piston on mid 1972-1974 cars
9.0:1 CR U.S. tii pistons
9.5:1 CR European tii pistons
E21 2.0 Head:
8.3:1 CR flat-topped pistons (used on 49-state '76 2002's,
US 2-liter 320i's)
9.3:1 CR domed pistons (used on european 4-cylinder 320i's)
Note: compression ratios given are with a stock head, and zero deck height.
-Jaycen PNW2002
