Front Control Arm Ball Joint Question
punchesdfw
I'm installing new front-end bushings and ball joints. My question is, how do you remove the 3-rivets from the old ball joints?
Thanks!
Drill them out. Use a bit that's just a little smaller than the hardware they gave so you don't accidentally enlarge the holes in the control arm. One side should have a dimple that will get you started. Drill out the head and use a punch to hammer it out. Takes about 5 minutes per arm. Make sure you're using GOOD grade 8 hardware to fasten the ball joints back to the control arm...
E36
you'll have to drill them out. start with a small drill bit, maybe 1/8 inch for a pilot hole. then redrill using bigger bit as appropriate. if you have the control arms off the car it's a minor job with a drill press.
if you're doing this under the car, make sure you have sharp bits, eyeglasses and plenty of working space to get good pressure on it while drilling.
it may be a good idea to hit them each with a center punch to make sure your drill bit doesn't wander off the mark.
& 1 special alfa
They must be drilled out with an electric drill and bit. Be very careful, though. Try not to make the holes to big or else you will ruin the suspension arm. I started out with a small drill bit and gradually moved on to a larger one to aviod this. If the holes are to large, the nuts that hold the new ball joint won't seat on the suspension arm properly, and you will have to get a new one. Take your time and everything will be cool. Good Luck!!
David G.
Keep in mind that a US grade 8 in metric hardware is actually called grade 10.8.
I wouldn't recommend using off the shelf nickel plated metric hardware, even if it says "grade 8.8", since that's equivalent to a US grade 5.
Blunt got me a a set of the original studs that are predrilled with the safety wire, and are the correct metric grade 10.8 (carbon finish). Don't wanna take any chances when dealing with steering!
Aashish
1969 BMW 2002--I gotta finish this damn thing
1987 BMW 325is--S52 Monster
1975 Innocenti Mini 1001-- the most cost dense car ever!
1995 318ti
2004 BMW 330i ZHP
2004 Toyota Tacoma (gotta have something reliable!)--can't live without
