flexible gooseneck map light
Armond
has anyone used them. if so, where did you mount it and where did you tap for power. thanks.
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
I have one, but can't figure where to mount it.
I thought I might mount it somewhere on the console or under the dash and then have it snake out for the co-driver, but the flexible arm is a bit short.
Glove box? Can't use it unless the glovebox door is open.
I'd considered mounting it to the A-pillar, but that means drilling holes and that's a "no, thank-you."
Considered the B-Pillar, but it gets in the way of the stock seatbelts.
If I had a roll cage, I'd mount it there.
But I don't, so it sits in storage.
Best option is an E30 lighted rearview mirror, IMO.
Cheers!
Delia
1973 2002tii - gone
Inka (aka "Orange Julius")
#2762756
1974 2002tii - gone
Polaris (aka "Mae West")
#2782824
1991 318is (aka) "O'Hara")
Brillantrot - High Visibility Daily Driver
BMW CCA #1974 (one of the 308)
deliawolfe@gmail.com
Agreed, this is what I will be installing in mine this weekend.
Another real cool toy is the VW mini torch flashlight. You can pick one up at the dealer. The price is a bit steep, but it is the perfect accessory in any car. You plug them in your cig lighter and they take up zero space.
Clicky for Ebay link
Armond,
how about a flashlight mounted to a baseball cap? wherever you are peering the light will follow.
or, alternatively, a small AA cell flashlight that you can install in your mouth temporarily whilst perusing a map.
however, i can see issues with this alternate suggestion if you are using this flashlight to locate an errant frenchfry for consumption.
& 1 special alfa
DJs too use those Halogen lights on a goose neck. They come in various length and can be either bolted to the center console, or just taped with double face tape or velcro. Very often, tey come with a variostat in the base that allows to dim the light.
Brake harder. Go faster.
I thought about that Jerry but I prefer a semi-permanent mounting option. Plus, I'll end up loosing the cap and the flashlight just like the 3 100 dollar oakley glasses I've lost so far in 2 years.
FAQ Member 1683
Mario Andretti
In addition, I've seen co-pilots use them on rally races.
FAQ Member 1683
Mario Andretti
you know Armond, 3 strikes and you're out!!!
i hope you're not wearing oakley glasses anymore, and if you are let me know and i'll follow you around till you misplace 'em. wonder what a used pair would fetch on ePay?
& 1 special alfa
