Bmw 2002 Badges HELP
eastsidebimmer
YES - the hood and trunk lid roundels
are larger then the roundel between the lic plate - tail light.
it seems people are trying to confuse you...you clearly stated you have a 75...not a roundie...as noted earlier, all roundels for the trunk and hood are the same size...
Same Diameter, maybe.... but not the same badge.
A Square rear badge had a curved bottom edge to match the curve of the decklid. The front badge is flatter and thinner since the hood doesn't curve nearly as much.
They're 2 seperate badges. One will not fit in the other's location.
the Square rear badge had a curved bottom edge to match the curve of the decklid. The front badge is flatter and thinner since the hood doesn't curve nearly as much.
both the hood and trunk roundel are the same on all years...you are aware there is a slight difference between the hood and trunk though
