choke warning light on early euro cars
I converted my touring to fuel injection and thus removed the manual choke cable. The cable had an electircal lead that, when the choke was closed (i.e., pulled), the e-brake light would burn. Now it burns all day long, but I can't find the lead (I think I hid it). Anyone know that lead and can you tell me the wire colors?????? I feel like my e-brake is on all the time, but of couse it is not.
According to the old 6-v diagrams, a single brown/blackstripe wire went from the choke switch to the gauge cluster. It looks like the wire connection was at the gauge cluster, so you probably will not see the wire any more once the choke switch is removed.
67 Caribe 1600
76 Ceylon 2002
Josh,
If I remember correctly, the wire connects to the choke cable at the control on the dash next to the steering column. It is probably grounding somewhere under the dash where you "hid" it. It is listed as Brown/Black in my German touring manual. I believe that the BR-SW designation means Braun (brown) wire with a Schwarz (black) stripe. I have attached a scan of that part of the manual. good luck
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
