INKA STEVE (and others) I grounded the "choke" wir
nothing happened. Warning light still burning bright. And, yes, I checked the handbrake.
Any ideas? AT this point I'm tempted to just remove the bulb and, as Tony would say, fugettaboutit.
Other than CD's suggestion, It was my thinking that grounding the wire would cause the light to light. I am assuming that you have already checked the Brake Fluid level, along with all the wiring and floats associated with it. The light is also the low brake fluid light. Mine comes on even if the level is just a little below full.
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
Mine doesn't have the brake fluid level sensor -- choke and e-brake.
I'll try C.D.'s suggestion, as I need an alt rebuild anyway....
On some later cars the 'master warning' light would come on if the seat belts were not clicked together IIRC. Beaner7102
