Ways to Improve the Parking Brake
Lola is having a time dealing with a sloppy parking brake handle. Are there any solutions out there for it; a new parking pin, washer/shims??
J.E.2002
sometimes the metal tabs that hold the handle break off of the tunnel and have to be welded back on. Check and see if both sides are still fastened to the tunnel.
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
IIRC, Paul Cain assembled a slop-eliminating kit. Also Armond organised a group buy for updated handles. Search "ebrake handle" for the latter.
Ray
J.E.2002
Ray
Hand brake kit from Paul Cain [pjcain@earthlink.net] removed the slop from
the brake handle in my car. The point of attachment of the metal sides that
the pin sets in had broken at the weld. Rewelding (brazing) and the washers
/bearings from the kit made it much better. Specify you car model if you
order because the 320i takes a smaller bolt. When you weld careful of the
brake light wire, the e-brake cable rubber collers in the tunnel, and the
carpet....it gets hotter than heck when you put the torch on that tunnel! There
is a way to do it without damaging everthing.
I have an e-brake handle from Armond. It's a nice piece. No slop, shorter and the actuation is smooth. Installation was done in 30 minutes.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
Usually due to vandalism. The welds break at the bottom of the bracket
and the hole becomes oval. ReWeld at the bottom of the support and
then find washer that fits over the pin. Drill, bolt or weld that into an
aligned position. then get a longer pin and clips. Shims inside the
handle would make it even better.
