Timing a '76 w/ dual action advance....
PeterVarga
I was told the procedure for timing is:
Advance vacuum hose remove temporarily and plug.
Engine off, verify 0 deg. TDC with piston on compression stroke.
Sync on plug #1 w/ timing light and look for mark at 2800 RPM.
Should be 25 deg. BTDC.
Retard hose remains connected during this proceduer.
Is this correct?
Thanks, Peter
Sync on plug #1 w/ timing light and look for mark at 1500 RPM.
Is this correct?
Thanks, Peter
'64 R27 250cc #383851 18,000m
