Need To Replace Blasting Media, What to Use?
justinevert
Ok, I need some help on this, I posted this a few weeks ago and got Squat.
I need to replace the glass media with fresh blasting media with the following charateristic:
Does not score, etched or basically damage the part being blasted
Minimal dust emission both inside the cabin for visibility (I like to see what I am working on rather than the Braile method) as well as outside I have to use masks not to breathe the stuff (Yes I already replaced the seals in the cabin)
Not harmful and must be enviromentally friendly (Well Duh!)
So far I have seen the following:
Glass beads, is there a particular size or weight
Baking Soda
Walnut Shells, again is there a size/weight preference
Finally besides Northern Tool and Harbor Frieght, where else to get it. I have tried PepBoys and AutoZone
Need so help, I have a lot of blasting to do
Thanks as always!
Justin
The question is not that we broke a few rules or took certain liberties with our female guests.
We did ;)
Charlie don't surf!!
Baking Soda
Thanks as always!
Justin
We did ;)
google: National Abrasives
No.24 glass bead is fine for medium to light rust and is easier on your spray nozzle.
aluminum oxide grit (220) is better for heavy rust and is quicker than glass bead, it's more aggressive and will.
do NOT use either of these on shiny aluminum trim pieces, but you CAN use either on aluminum bits on the engine without problem.
i blast steel parts at 60-80 psi with aluminum oxide
and glass bead at 40-60 psi.
use a vacuum cleaner to clear the air within the chamber
Trinco is a maker of reasonably priced cabinets and filter systems. they are a supplier to Dayton and i bet Eastwood, too.
& 1 special alfa
& 1 special alfa
