rear axle carrier mount (roundie vs. squarie years)
ryanOC
apparently these are different between the two, and i've managed to get the roundie ones instead of the squarie ones
do these bolt up differently? do they not fit?
don't want to have to return these, but will if i have to
roundie #: 33331103926
squarie #: 33331113342 (left) 33331113343 (right)
1969 2002 Automatic "Pumpkin"
you can use either set.
i *believe* the difference lies in the slight difference in the orientation of the rubber bushings within the metal sleave. it has no impact on alignment of the metal sleave, but rather takes into account the difference in bending angle during use.
there, did i make that confusing/garbled enough?
short answer - don't worry, use em, but be mindful of the left and right side.
& 1 special alfa
The orientation pegs are different. I forget which one is which but they are different.
Sorry to not be able to tell you which is which but I know they are different.
I believe on the square lights you have to order a left and right and on the round light cars one fits both sides.
1972 2000tii Touring #3422489
FAQ member #5
Sir Williams you are correct -
one size does Not Fit ALL
you have to put the bolts through the carriers then put the bolts through the subframe.
If you put the carriers up against the sub-frame then try and put the bolts through both, the angle fights you.
FAQ member #5
well, as suspected, my answer was sufficiently garbled as to be misleading.
what i interpreted the question to be, was whether it was possible to use the Roundie-version mounts on a squaretail car or the Squaretail-version mounts on a roundie.
my answer is yes. and i am unaware of any difference in geometry or bolt/stud sizes between the two body types wrt this area. i believe the rear subframes are identical and bolt hole placement is identical.
it is required, as Bill stated, that the bolts be inserted into the mounts prior to fitment onto the subframe, but that's common to both p/n variants.
if indeed i am mistaken then i humbly apologize and will crawl under my rock again.
& 1 special alfa
let it be known that i USED THE ROUNDIE bushings on it, and had no problems (other than what was expected w/ half-dropping the subframe...)
it's all good!
i suppose the wearing rates on these might be different due to the angle of rubber within the sleeve. oh well, better than the old shit i had on there.
thanks for letting me know!
