Stock Shock Rebuild?
FL02
Has anyone rebuilt the stock boge shocks on a 2002? My car is fully stock and in pretty good shape (1969 2002). The problem is, it rides like a pogo stick w/ little dampening from the stock suspension. The shocks are in good shape and I'd like to rebuild them instead of getting billsteins if I can. I'd like to keep the original feel of the car, and think a rebuild would fix the pogo issue. Is it hard to rebuild the shocks? Do you think it would be a matter of cleaning and putting in some new suspension oil? Anyway, just wondering if anyone has rebuilt their stock shocks, and if they had any suggestions or warnings about a stock shock rebuild.
i rebuilt my late 71 Malaga car stock including returning the single barrel solex carburetor.
the trunk had a pair of new Boge struts in it when i bought the car so i used them. on the few times i've driven the car so far, it's been a lot of fun. it's easy to slide around corners and will lean a bit more due to the stock sway bars, i believe. it's a different feel from the 75 i had with LS differential, thicker rear swaybar and slightly wider tires.
& 1 special alfa
Use BILSTEIN " HD " shocks at all 4 corners -
your car is 30 years past due for this Service !
it will be comfortable, sporty, as originally designed.
'64 R27 250cc #383851 18,000m
The Boge dampers are actually pretty nice for a daily driver/touring. I installed a set on a '73 I just bought.
Good dampening for OE springs and a nice controlled ride without the hashness of a high pressure gas damper/shock. The rear shocks are a nice semi-gloss black(stock looking). I would also suggest you replace the front bumpstops as the originals deteriorate with age.
They're also a great value. E-mail me if you're interested in a set. I can usually ship within a day.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
