headlight bucket differences...
robspeed
I would bet the "short" ones are for late model 02's 74-76, they still need the flat black ring that holds the headlight in. The others would be for the earlier models. I think if you remove the top portion of the "long" ones, they would be identical to the short ones, which are missing that portion. Just an educated guess.
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
AHhhh, but witch one is the right side and witch one is the left.
That will become quite obvious as soon as you try to bolt them in....
The short one is for a square light. I took mine apart and had them replated, and as I recall, they are the same part for both sides. Not sure if the same holds true for the earlier versions. I have the early grills on mine, and there is a noticable gap that would be filled by the early buckets.
Stacey
Columbus, OH
No cup holders, by design.
'76 O=00=O   '77 R100RS  '85 K100 '01 325CI   '05 330XI ZSP   '80 Porsche 911SC
