Carbon fiber driveshaft,Tilton reverse mount starter
flybmw02
This is my new set up in my 2002 GT-3 car it's a Tilton chevy ultra low ground clearance bellhouseing with a 8" ring gear a two disc clutch with a hydraulic release bearing and a reverse mount starter. I set it up for a saenz 5 speed trans. And a carbon fiber drive shaft.
I can't wait to drive it.
The bellhousing is the easy part I only drilled four holes in it and trimmed the edges. The butten flywheel is a Quartermaster that has the correct bolt patten but it needed to be spaced out .700" so I cut the back off an junk crank and machined it to index center. The flexplate is a NLA tilton 102 tooth chevy I have five of them. I hog out the center and drilled eight holes and it fits perfect to the back of the butten flywheel. The adaptor plate is 3/8 plate aluminum I leved the car perfect used a plum bob to find vertical and used a dial indicator off the crank and centered the bellhouseing drill dowls holes to keep it centered and drilled the rest of the 3/8 holes and cut off the extra. In the plate I used Time-Sert steel theaded incerts because of the thinness of the plate. The trany plate that bolt to the bellhouseing I had to cut down the thickness so the imput shaft would engage the inner clutch plate. I am waiting for 1/2" incerts for the trany plate. I am adapting a 1310 flange yoke for the differential and the I can order my carbon fiber driveshaft witch is an off the shelf item. Tilton will make a butten flywheel but even as a dealer it cost around $1400.00. I bought almost all the bellhouseing stuff on ebay and I have only spent $980.00 plus the $3500 trany and $560 drive shaft. But I sold my old Nissan tranys and extras for over $5500 so i am still a little ahead.
  • 4 weeks later...
I don't have a link I wish I did. I just have not had the time I spent the day installing a new mini mini alternator to replace the old mini altenator. I still want to install a pump, filter and cooler for the transmission that's why there is a pully on the front of the drive shaft. It seem I have the car ready as soon as the season is over. I was planing on going to many races this summer but with the gas prices at $3.60+ a gallon I think my travling is going to be limited.
I will post some pictures soon.
John
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,298830/highlight,/
http://www.youtube.com/watch?v=aeuNT-UCbxE&feature=related
