deep or shallow front grill for european headlight buckets?
Armond
just scored a pair of euro headlight buckets. I dont believe I have the "deep" style grills. TIA
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
all the side grilles are the same us or euro., plastic or aluminum
so what's the purpose of making Shallow and deep style grills?
FAQ Member 1683
Mario Andretti
There were a few variations on the Euro light bucket assemblies - if you're talking the WHOLE Euro set-up - not just the aftermarket H4 stuff.
One series of part numbers for Hella brand assemblies
One series of part numbers for Bosch brand assemblies
There's at least a third one used in the pre 74 carsm that I've seen - using really wacky mongo sized bulbs as well.
then..there are different bucket assemblies for the Euro plastic grille era cars I think.
Now....with that said - as long as you have either Hella or Bosch early type bucket assemblies - you'll want the deep grilles (used on US cars until mid 72 I believe) - this makes the glass come FLUSH to the grille opening - no "chrome rings" used - just a rubber gasket.
it's a sweet look. Cost me plenty to get 'em new a few years ago for Emily....5w city lights and all. it's fun to shut the car off and flick the signal switch from left to right and see the car "wink" left and right through the headlights. :-) heh heh!
Paul Wegweiser
Paul Wegweiser
Paul Wegweiser
Paul,
Do you have a pic that you can share with us? This sounds pretty sweet.
Thanks
Hamada
70Bristol02 E36M3 E34535im
I looked for a photo of Emily close up before posting....couldn't find one. I'll snap some this week. They're definitely a cleaner unique look compared to the US ones. I never realized how clumbsy looking the American stuff was til I got rid of it. FYI - Mine are Bosch - at the time BMW wanted a bit less for Bosch vs. Hella part numbers.
Paul Wegweiser
Paul Wegweiser
Yep!
In fact - when wired correctly - the little rubber grommets at the 6 O clock position behind the headlight actually "make sense" - no longer having a parasitic non-grommeted wiring addition feeding the turn signal assembly "USA" type parking light.
Another item of note - I recall US buckets being uniquely left and right, whereas the Euro ones I have are the same part number for each side.
Paul
Paul Wegweiser
very difficult to tell apart, so if you take yours off, mark 'em so you won't mix them up...Otherwise the lights will point everywhere but up the road (ask me how I learned that!).
And Paul, the "mongo-sized" bulbs you mentioned (pingpong ball sized) are the pre-halogen Euro bulbs whose use goes all the way back to the late 20s. I have a Marchal headlight that's probably from a late 20s Amilcar that uses that bulb.
I did the "Euro" bucket setup with a hi/low HID setup. I like how simple the bucket assembly is.
I also added Lamin-X to help protect against rock chips.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
