What would be the best dive shaft and diff for a m20 2002?
Use an 02 shaft and have the front section sized whatever trans you use. I had a 320i shaft laying around so I used that, but it's more work than it's worth, and probably isn't any stronger. CSB is in a slightly different location.
Mike
Mike
Sorry mate i idnt understand one thing u said there, Do u rekon i should go for the e21 323i diff and e21 drivr shafts?
regards
Drive shafts or half shafts? If it is drive shafts, then Mike's answer is perfect. If it is half shafts, then you may want to look at the following links:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,304652
http://www.bmw2002faq.com/content/view/17/32/
The best diff, as in the easiest, would be a lsd from an e21 323i, if you can find one.
You'll find more under search.
(... also, it may help to post under General Discussion.)
David
Cheers for the help mate, i already have a few LSD's at home, an e21 3.45, e30 4.10 and e28 3.46
