Attaching Rocker Panel Molding - Advice Needed
OK,
My clips are correct and new. They are white, not tan.
I think I did a better job installing this time, following Esty's instructions.
I attached the front metal clip with nut and supported the back end with appropriate height of 2x4s. Then I marked the trim so I knew exactly were each clip was.
Starting from the front clip.
I made sure that the top edge of the trim was pushed in and firmly down onto the clip and then pushed the bottom in. I then felt and heard a very nice click into place. I did not hear this the first time I installed it.
I did this for each clip and felt/heard a good click when it snapped in to place. The difference was in how hard I pushed in and down to get the top edge of the trim onto each clip, before popping the bottom in.
I am feeling confident about the permanence of this install and will report back to this thread if I have a failure.
I echo the directions above.  I just put my rocker panel trim on and it's snug, tight and I am happy.
