are brake boosters rebuildable?
Benetton
i bought a tii booster a couple years ago and it is just now time to install it on the car but when you blow or suck on the vacuum port air comes through. so am i sol or can i rebuild it? if not does anyone have one for sale? i need a tii booster to use my dbilas air filter.
Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on
-= no =-
factory sealed and non-serviceable
damn well does anyone have one they want part with? shoot me an email. tia
Try stainless steel brakes. I believe they are located in NY. The price may be steep but still cheaper than buying a new one.
shermanmartinez@hotmail.com
Yes - we have it done all the time.
whats the cost to have it done?
Well, a little study of how it works and if you don't have a MC installed on it, you won't get much results blowing or sucking on the vacuum connection.
i wouldnt be posting if i knew how it worked. how do you test one then?
Send it to Rob Torres at 2002 Haus or to Jack Fahuna at JF Pro and they will have it rebuit for you. Contact them for pricing. It may not be cheap but I promise it will be a lot less than a new unit.
Pierre
O==00==O
Yes. The M/C completes the seal. If you don't have a MC bolted to it, you will never get any vacuum.
John
thanks john i'll bolt it up and try again this weekend.
