spare tire/wheel
caps02
What are some of you using as a spare? I'm running 14 inch wheels with 195/60R14 Yokohama ES100's on the street with a Korman big brake upgrade. I was debating about restoring the original 13 inch spare, or going with an E30 steel wheel (with 195/60R14 tire?). Can I get away with using a 13 inch with 185/70R13 combo as a spare or do I need to get the matching 14 inch size? Are there any problems physically fitting the 14 inch combo in the spare tire well and under the wood floor panel (I'd still like to be able to stow it where it belongs!).
TIA!!!
-Rob-
1974 2002
Rob Capiccioni
1974 BMW 2002
2003 Ducati Monster 800S
2007 Acura TSX
This issue was discussed in depth this Summer on the FAQ. Here's a summary: anything fatter than the original 165X13's may not fit under the existing flooring. The flooring can be raised with wooden risers around the edges in the trunk to accomodate fatter tires. So 185X13's and 195X14's will fit in the spare tire well, but will be too fat to fit under the original flooring arrangement.
I run 195X14's on bottlecaps and carry locally a 165x13 as a spare since it has about the same outside tire diameter as the 195x14's. When going longer distances, I throw a 195X14 on an E30 steel wheel in the trunk as a better sized spare. Fortunately in eight years, on good rubber, no flats yet.
Good luck.
____________________
Roger
'72 Malaga
YES - get a 5 x 13 original steel rim,
mount a 165x13" tire , and your good to go.
You can order a new steel rim from any BMW Dealer,
and order the tire from Tire Rack.
You need to carry a set of "STEEL WHEEL "
LUGNUTS FOR THE SPARE BECAUSE YOUR ALLOY WHEEL
WHEEL LUG NUTS ARE A DIFFERENT TAPER.
use the wrong taper lug nuts with the wrong wheel,
and loose your nutts and the wheel !
( the following illustration goes for nuts as well as bolts )
'64 R27 250cc #383851 18,000m
Is it 165/65R13 or 165/70R13? I don't recall what was on there when I removed the original spare. TireRack lists tires in both of those sizes. I have one more question--what color should the original 13 inch steel spare be? Mine was painted Fjord blue--just like the rest of the car. I thought they were supposed to be silver.
Thanks,
-Rob-
Rob Capiccioni
1974 BMW 2002
2007 Acura TSX
