Ok, finished or at least done quit whateve on nuts and bolts
BillWilliams
I took some time and made another look at the spreadsheet on compiling the nuts, bolts on our cars with BMW part numbers. I have no idea why anyone would need this but I was on a mission.
The complete deal is in the FAQ Constuction Zone Section.
If you need or want the spreadsheet, send me an e-mail
1972 2000tii Touring #3422489
FAQ member #5
It is funny what you do when you are bored, tired or laid up.
I to have spent numerious hours or days to accomplish something.
When I finish at 3am and crawl into the sack I think great, now what am I going to do with this.
I would like a copy of that Bill. I will find a use for it.
Thank you.
Joel.
penth2o_2@charter.net
bill, i think you should seek professional help......
that is an amazing effort
you raise the anal-retentive bar to an amazing height.
what i've done for my needs is assemble reference packets of all the nuts/bolts/washers for a particular assembly and store them in my reference box.
then i merely pull out the applicable packet and dig through my parts drawers to assemble the necessary bits.
& 1 special alfa
Bill,
Thanks for your efforts with this. I'm confused by the pitch column, shouldn't the pitch be the distance from one thread to the next in millimeters? M6x0.8-15 HHS for a M6 hex head 15mm long with a pitch of 0.8mm per thread?
Todd
"Common sense isn't common"
gauge for this? I may have used that instead of the metric one.
Let me check, I was afraid I may have screwed that up. If so, I have a lot of emailing to do. Oh well, I can get that done.
However, the part numbers stay the same. It only matters if someone is to order the bolt with a US pitch, then they can say the guy who created the spreadsheet is a crazy guy.
I just checked and you are correct, I used the US pitch guide.
I will busy myself in fixing it.
Thanks for catching that.
FAQ member #5
