WTB : tii gas tank
Hutton
pickup assembly (twis on 72 tii) is covered with about an inch thick of gunk .....Is it worth trying to clean?
The tank has a tear PO did a repair job with some gasket sealer or something...Oh well the tank leaks now.
The gas gage unit is also full of gunk. I would like to try cleaning everything my self then have the tank repaired. Any suggestions?
And yes the car has been sitting for about 6 to 8 years.
Chris Hutton
72 02tii Ceylon 2761758
71 02 Sunroof Riviera 2574316
68 1600 Bristol 1565358
88 535is sold
The tank design changed in 72/73, and some cars have had their tanks changed (like mine) over time.
Per the BMW Parts CD, the twist-in type pickup and tank arrangement was used in USA tii's from VIN 2760001 to 2761963. After that, the bolt-on pickup and tank set-up was used.
In your case, I would just make sure the seller includes the matching pickup with the tank.
Also, be aware the older type sealing ring for the twist-in tank is only available from BMW dealers (# 16121105332). The bolt-on type flat seal (# 16121110598) is available from aftermarket suppliers.
