This winter's E-production race car projects...
TobyB
I got ambitious last fall and took on maybe too many improvements-
it's only time and materials, after all-
so I thought I'd put it all together here so you- all can point and laugh.
Today it's the transmission adaptor's day.
It's just a section of a bellhousing welded to an inch- thick spacer plate.
The thickness was dictated by the flare of the bell and the bolt pattern
of the transmission- any thinner and the bolts ended up right in
the plane of the bell.
Joe the Welder (yep) did a great job considering how different the
materials were. He said the bell had contamination, but not enough
to compromise the strength.
More as it goes together.
It's the most exotic 2002 in the world.
Yeah but hes also running a newer (3.0L) motor that is turbo'd, right?
Is this (the rear tranny setup) cost effective? Im assuming no but hey, never hurts to ask.
75 2002 "Project Turb02"
95 Hellrot M3 *Sold
95 332is *Sold
Funny- I tried to make a Volvo 142 trans and the GE motor fit back there
with the the stock diff- and it would ALMOST work if I cut off the trans
input shaft and went clutchless...
Anyway, the transmission does fit. It hits the stock
mounts going in, so I guess they have to go.
Sadly.
And it's about 1/2'" too long in the shifter as it sits now.
(it's a Nissan close- ratio "4" speed... out of a roadster)
To the driveshaft shop tomorrow to see if they
can make me a 52 3/8" one- piece...
