Bolt from Hell E30 Tranny.....Anyone
Richard
I asked a friend that works on E30s a lot, and here's the discussion:
Friend: it really ain't that horrible
you need external torx bits
E10 8 and 6 I believe
Kevin: tell that guy
where is it?
Friend: I imagine he might also be refering to the two top bolts as on the M20 they are hard to get at, need about 4ft of extensions and swivels to get access
otherwise not really sure what the bolt from hell is
Kevin: hah
maybe hes just a pansy
Friend: there is also a hidden 8mm screw that can be annoying
you think all the bolts are out, try to split the engine and tranny and it won't move
because of that dinkly little 8mm that is on the engine side of things, very odd
Bring a Welder
I don't know what you mean. All the bellhousing bolts on my E30 M3 are way easy to reach.
Wait, is this on a 6 cylinder E30?
If so, then that's the problem. Somebody stuffed a couple of extra cylinders in your way. Loose them and you should have plenty of room to access the bolts.
Otherwize, swivel-head torx sockets on an extension are needed.
Steve J
& too many bikes
Just did it with an automatic. As stated above. We had some one to turn the socket, someone to hold the tranny up to keep the pressure off it and someone to hold the light. Put the socket on from top and then mated the extention to it. I will add that it was a real bitch to get.
know or have a tool or method to remove the bolt from hell on an E30 tranny... If your not familiar with this bolt you have never removed an E30 tranny.....TIA
ive never done the e30 tranny but i have heard of the bitch bolt. ive done a few older mercedes trans with a 4' extension and a wobbler on the top bolts. a few blasts with an airgun and yer done (on those).
