FIFTYTAKEDOWNS FANTASTIC GARAGE TURBO BUiLD 9000 + stroker
To make a long story short today, *5 hours of attemtping* the motor wouldnt mate with the tranny, the trans is coming out.
tons of pictures uploading as we speak
  • Replies 44
  • Created
  • Last Reply
Top Posters In This Topic
Got motor Mated w/ tranny, bolted into mounts. and started hooking everything up.
Wiring is going to be a nightmare.......
There is also like 0 space for anything.
pictures coming up.
  • 1 month later...
Well, The Car Ran and Drove, I drove it around, and wasn't pleased witht he CIS system. there were NO vacuum Leaks, timing was dead on, and it was getting fuel.
Im getting a new turbo, and manifold that dont Spray oil all over the place. and MEgasquirt.
I already have the sensors, and expect the computer to come this week. I took off the old manifold, and all the hokey pokey CIS stuff that I hated. and now the engine bay is much much cleaner.
soon I am to order teh ebay intercooler, and hit up the junkyard for a better T4 turbo.
Ohh the manifold in the pictures loos all funny, we were test fitting to see if manifolds could be flipped.
  • 4 weeks later...
Lol updates:
EDIS on the Way
Hoses in place, and Fuel system Working perfectly, currently awaiting spark for startup.
So far its Naturally aspirated Until my boost bros manifold comes. WIllb e powered off of an 300 ZX turbo. The megasquirt is almost all hooked up. just need to figure out how to dial it all in.
If anyone has any NA m10 maps send me a PM, thanks.
  • 2 months later...
First on My list of concerns to finally get the Turbo on is the oil feed, and return. Seems like Ebay has some fittings for the turbo, but Im not sure if it is the right thread for what I have.
Here is what I am dealing with
IMG_2242.jpg oil line from oil filter housing
Oil Feed on turbo
Oil Return on Turbo
Oil Return Into Tank.
Obviously the return to tank is just a hose, but there were return lines that fit to the turbo that that hose will fit over.... Defintiley will be going threaded line if I can figure out the right measurements
Next Up I got the Crank Pulley
EDIS bracket
pulley installed
trigger sensor and pulley installed JUST BARELY clears!
Took a random break to seafoam the 318 and take some artsy pictures
Still cant figure out how to Do this Throttle Linkage
These are supposed to hook up to the Throttle body... but I have no Idea how...
Linkage
Linkage with the TB think I have to connect it to somehow
NOW the final EDIS wiring
CoilPack
TPS Wiring
Vacuum Lines to MAP/boost gauge
So you see this Red Wire is a direct power source from battery that is connected to the Megasquirt, and the Injectors simultaneously.
It is turned on, and off with a manual switch on dash think the red wires say 12 vol or soemthing
Also there is the INJ1/INJ2 wires that go to the injectors as well..red power wire snuck into photo
I wired the EDIS 4 Module exactly as that Diagram
IGN wire
Pin 8 of edis4 seemed kindof Odd, so I plugged in a wire source for the power right there. which was being retreived by the coilpack. you can see how that power wire kinda t's into there
It's sort of a nest
Aside from that stuff The turbo mounting is gonna require some elimination fo radiator support. not sure If the Turbo I have is the same as Cody's but it will seem like cutting it close:IMG_2243.jpgIMG_2244.jpgIMG_2247.jpgIMG_2249.jpgIMG_2250.jpg
CLIFFS:
Turbo Mounting problems
Car wouldnt Start, but sensors Were reading
(no 02 sensor plugged in yet)
my wiring is ratty
Need to figure out getting oil to turbo....
My Megasquirt Is already programmed with MSnS extra, so hopefully I didnt do any wiring wrong.
Nice build up! do you have the Capacitor hooked up? i did not see it in your pictures, read in post that it is very much needed.
Line from switched power goes to a T. One leg of the T goes to Pin 8 on the EDIS module, the other continues on.
That leg then goes to another T. One leg of the T goes to Pin 2 on the coil pack, the other leg goes to the 25uF capacitor and then to ground.
hope this hepls
FO 2573825
1971 2002, 5-OD, Recaro SE, BBK, 90Amp Alt, Turbines, VDO, Hellas, BD belts, LED Tails, 10 Foot DD
Ive been looking online, and seen many different kidns of 25 Uf capacitors. I dont understand how some of them hook up to the wiring, or which is the right kind to use (from radio shack etc..)
Thanks
